lördag 04 juli 2026
Bernte-AQ
Byta septislang pga lukt
Ska byta slangen mellan toan och tanken för att försöka få bort lukten av ladugård. Läste i Aquador tråden om Jonas som bytt på sin båt med gott resultat, slangen som han använt hade blivit grå efter en kort tid och det är ju inte så snyggt när man ser så pass mycket av den. Är det någon som hittat en vit septislang som förblir vit även efter ett par år.
Tack på förhand. /Bernte
Inte helt enkelt att hitta rätt slang:.
Sanitation Hose: Lots of Folklore
Sanitation hose has long been the subject of a whole lot of debate. A headline in the September ‘93 issue of Practical Sailor was only one of hundreds over the years to trumpet Hose is the key to odor control! It’s a perfect example of the folklore that that has been a part of the marine industry forever. Some experts insist that anything less than double walled hose is unacceptable, some even recommend the use of rigid PVC. In fact, the first is an unnecessary expense, the second could be the worst thing you could do.
There have been problems with hose in the past, and there is hose on the market today that is totally unsuitable for sewage. It’s impossible to determine, just by looking, whether a particular white flexible PVC hose is suitable for use in sanitation systems or not. Out of ignorance, even reputable boat yards have made incredible mistakes, even installing corrugated blower hose in the system.
Hose is indeed often a source—but not the cause—of odor. If sewage stands in any hose, it will eventually permeate the material, so if possible, run your hose without any low spots where sewage can stand, and always be sure flush the head sufficiently to push all the sewage out of the hose and rinse behind it. As part of the routine of closing up the boat, close the intake seacock, flush the head dry, then pour about a quart of fresh water into the head and flush that through the system completely. If limited holding capacity makes extra flushing each time the head is used impractical, following this routine when leaving the boat will solve most odor problems.
Sanitation hose should be flexible smooth-walled PVC with an ID (inner diameter) of 1 1/2 --except for the discharge from a macerator to an overboard through-hull--(installed below the waterline, please!) which is typically 1).
Till slang för septitanken så skall det vara en rejäl slang av lukttät typ.
Köpte denna till gamla båten när jag satte in tank och ny stol. Vit och snygg när den var ny, vet dock ej hur den kommer att se ut om några år. Bilden visar under montering, (massa sågspån mm) den vänstra slangen har skyddsplasten kvar.
Köpt på Erlandssons http://www.bryggan.nu/Hemsida/Inredning_VVS/Slang_Rordelar/Slang/SANITETSSLANG_EXTRA_38MM?id=04883
Har senare köpt liknande slangar på en annan affär men de var inte lika snygga, de var mörkgula vilket inte ser lika snyggt ut.
Var nere och monterade en panel med kopplingsplitar i båten idag för att försöka bringa lite ordning i elröran. På boiden jag tog fastnade en 4 år gammal toaslang. Den har förståss hela tiden befunnit sig i mörker bakom panelen med strömbrytare.
Ser att jag glömt ta bort skyddsplasten - vad det nu kan ha för betydels!?
Lundgrens står det tryckt på sidan. Inköpt hos Hunnebo Båtinredning en återförsäljare till SeaSea.
Nu har jag inga slangar som är öppet förlaggda. Kan inte märka att de skiftat fär nämnvärt på 4 år.
Tack så mycket för hjälpen allihopa, har nu beställt slang från boatstuff så får vi se om den håller sig vit ock luktfri.
/B
Slangen är fortfarande vit och luktfri, hoppas det fortsätter så ett tag till.
