MinnLT 2 Postad 8 Juli , 2020 Hello, I'm just wondering does anyone still have Ohlson 22 sailboat papers with technical details from Fisksätra shipyard? Or maybe where are official records in Swedish sailboat registry? Any help is appreciated. Regards, Ohlson 22 owner Mindaugas Dela detta inlägg Länk till inlägg Dela på andra webbplatser
ChristerN 2 692 Postad 8 Juli , 2020 Have you seen this https://www.sailguide.com/batfakta/ohlson-22 Dela detta inlägg Länk till inlägg Dela på andra webbplatser
MinnLT 2 Postad 8 Juli , 2020 Hey, ChristerN, Yes, I did have seen all websites with this data. I provided it for authorities, but they do not accept it as official data. I'm wondering is there any "more official" records for this sailboat model? Regards, Mindaugas Dela detta inlägg Länk till inlägg Dela på andra webbplatser
ChristerN 2 692 Postad 8 Juli , 2020 Hi, So you need some “official data” to provide to authorities, right? I guess those authorities are not in Sweden? I also guess that there are no lawfully correct data available in Sweden but, however unlikely, there is a chance that there somewhere in some official archives is stored the original drawings of the boat if that would be sufficient. Do you think so? What those archives would be and where they would be located I couldn’t guess. Only possible alternative I could think of is Sjöhistoriska Museet in Stockholm Doubt it is possible to get hold of them at this time of the year though. Could be worth a call though. Maybe someone else here has better knowledge of where those could be found? Dela detta inlägg Länk till inlägg Dela på andra webbplatser
per_62 226 Postad 8 Juli , 2020 Hard to find any information of Ohlson 22 Check http://www.ohlsonyachts.com/ and Yachts/Drawings for a old drawing. Here some more info: https://www.maringuiden.se/files/batguiden/pdf_70tal/ohlson22.pdf http://www.livetombord.se/praktisktbatagande/artiklar/artiklar/20090622/prisvard-ohlson-22/ Some owner should have a brochure of the Ohlson 22. 1 Dela detta inlägg Länk till inlägg Dela på andra webbplatser
Swe195 1 Postad 8 Juli , 2020 Hi, what data is asked for? We dont have any official register. Here is a link to the data from the swedish handicap system SRS maybe that could be https://matbrev.svensksegling.se/ReportViewer/ReportView.aspx?sId=21405&rpt=Ohlson 22 Dela detta inlägg Länk till inlägg Dela på andra webbplatser
MinnLT 2 Postad 9 Juli , 2020 Thank you everyone for your support and directions I have found that I was looking for in http://ohlsonyachts.com/drawings/ and it redirected me to http://register.veteranbatsarkivet.se/ I searched for "Ohlson 22" and it provided detailed information: http://register.veteranbatsarkivet.se/IMG/UploadedFiles/20200624164627MSF_20_2_O22-0001.jpg http://register.veteranbatsarkivet.se/IMG/UploadedFiles/20200624164645MSF_20_2_O22-0003.jpg http://register.veteranbatsarkivet.se/IMG/UploadedFiles/20200624165155MSF_20_2_O22-0012.jpg 2 Dela detta inlägg Länk till inlägg Dela på andra webbplatser
