onsdag 28 januari 2026
andreascarlsson
How To - Lägga till L1/L2 på Garmin VHF 100i/200i
Här är en guide hur man lägger till L1/L2 på Garmins VHF-modeller 100i och 200i. Den finns (vad jag vet) inte någon stans på nätet.
God lycka till alla Garmin VHF ägare!
/Andreas
Using the VHF 100i and VHF 200i to Program Private Channel Sets
You can program a private channel set using the radio. When you add private channels using the radio to the current International frequency bands. The radio provides only a basic interface for adding private channels. If you require additional programming capabilities, use the Garmin VHF Radio Programmer. The Qatar and United Arab Emirates private channel sets can only be programmed using the Garmin VHF Radio Programmer.
Private channels are inserted at the end of normal radio channels as showing in the following example:
·          Private channels added: F1, F2, F3
·          Channel ordering on the radio: 87 > 88 > F1 > F2 > F3 > 1 > 2
To add a private channel set:
1. While pressing and holding the left soft key on the radio, press the PWR key to power on the unit. The screen displays “ENTER PASSCODE:”.
2.  Use the Channel knob to enter the passcode: GARMINVHF.
3.  Select OK to acknowledge the warning message.
4.  Select PRIVATE CH..
5.  Select a private channel set from the list. Select NONE to clear a private channel set you have added.
The following table indicates the channel sets that you can add using the radio.
Country
Channel Set
Channel Designator
TX Frequency (MHz)
RX Frequency (MHz)
Belgium
Belgium
96
162.425
162.425
Denmark
Denmark Leis.
L1
155.500
155.500
L2
155.525
155.525
Denmark
Denmark Fish.
F1
155.625
155.625
F2
155.775
155.775
F3
155.825
155.825
Finland
Finland Leis.
L1
155.500
155.500
L2
155.525
155.525
L3
155.650
155.650
Finland
Finland Fish.
F1
155.625
155.625
F2
155.775
155.775
F3
155.825
155.825
Holland
Holland
37
157.850
157.850
31
157.550
162.150
Norway
Norway Leis.
L1
155.500
155.500
L2
155.525
155.525
L3
155.650
155.650
Norway
Norway Fish.
F1
155.625
155.625
F2
155.775
155.775
F3
155.825
155.825
Sweden
Sweden Leis.
L1
155.500
155.500
L2
155.525
155.525
L3
155.650
155.650
Sweden
Sweden Fish.
F1
155.625
155.625
F2
155.775
155.775
F3
155.825
155.825
United Kingdom
United Kingdom
M1
157.850
157.850
M2
161.425
161.425
Tack för instruktionen den fungerade klockrent. Dåligt att detta inte finns på nätet eller i manualen.
