måndag 02 mars 2026
veikoherne
Can someone help me to get foresail line up to mast again
Hi
I’m in Malmo area with my small sailingboat and awhile ago managed to drop down foresail line. So, having only main is kind of temporary solution and I’m scared to take longer trips with her. The mast is over 7m meters high. If I would had harnesses and somebody will use halyard to pull me to the mast, then I would have done it. But I haven’t met anyone yet here willing to help.
Sure, if somebody have crane code and we can move the crane…
Thanks,
Veiko
Surely your club has a mast crane, just go to it and land the boat by it. Then climb the crane and pull it down. (Or maybe i understand your issue wrong?)
Thanks.
Basically I got issue solved already. Just used mast winch ladder and tied a rope to my mast to bring it closer to my position.
I was surprised, that nobody was willing to winch me up here using my halyard. Should have been easiest solution as my boat mast is only something 7m high.
I’m not a member of any sailing club and have no plans to join. Just stuck with my boat in Sweden too long. And maybe have to stay over winter here.
Veiko
