tisdag 28 juli 2026
Maltebesk
Problem med laddning
Jag had en batteribank på 5x120Ah Gel batterier. samt en Mastervolt Chargemaster 50 A.
Nu har laddaren stått på i två dygn, batteritankmätaren visar 100% men den fortsätter trycka in 2 amp och spänningen
visar 14.3 volt.
Varför går den inte ner på 0 när den är full laddad?
Hej, tack. Alla förbrukare är avstängda. den fortsätter ändå tryck in. Kan det vara något kortslutning i ett av batteri?
Manual:
The bulk phase is followed by the ABSORPTION phase. Absorption charging starts when the voltage on the batteries has reached 14.4V (12V models) / 28.8V (24V models) at 25°C / 77°F, and ends when the battery is completely full. Battery voltage remains constant at 14.25V (12V models) / 28.5V (24V models) at 25°C / 77°F throughout this stage, and the charge current depends on the degree to which the battery was initially discharged, the battery type, the ambient temperature, and so on. With a wet cell battery this stage lasts some four hours, with gel and AGM around three. Once the battery is 100% full, the Chargemaster automatically switches over to the float phase. During the FLOAT phase the Chargemaster switches to 13.25V (12V models) or 26.5V (24V models) at 25°C / 77°F and stabilises this voltage to maintain the batteries in an optimum condition. Connected DC-loads are powered directly by the charger. If the load is higher than charger capacity, the required additional power comes from the battery, which will be progressively discharged until the charger automatically switches back to the bulk phase. Once consumption decreases, the charger goes back to normal operation of the three-step charge system. As the Chargemaster is equipped with a three-step Plus charge system, the batteries can also remain connected to the Chargemaster in winter. One hour every 12 days the charger automatically switches to absorption to keep the battery running properly and prolong its life span. The three-step Plus charge system is also safe for all the connected equipment.
Kan det vara någon förbrukare som drar ström tex minne till stereo mm?
Kurt Vilen
Stockholms Marine El
www.båtelektriker.se
Kan vara ett batteri som är dåligt. Det bästa är att kolla med en tångamperemeter och stänga av laddaren för att vara helt säker att inte det finns någon förbrukare som drar ström. För att kolla batterier så är det en batterianalysator som talar om i klartext kondition på dina batterier. Givetvis mäter man dom separat inte ihopkopplade med andra batterier då du använder batterianalysator. Att bara mäta volt på batteriet är inte en 100% information!
Kurt Vilen
Det är väl tre utgångar på den, är alla tre utgångarna inkopplade?
Är det en förbruknings utgång samt en startbatteri utgång som är inkopplad?
Kurt Vilen
Var läser du av 2 amp? Har du en batterimätare? För Mastervolt Chargemaster 50 A har inte en digital display vad jag kan se, 70 amp modellen har display där du ser laddningsströmmen.
Kurt Vilen
www.batelektriker.se
Har kopplat bort den utgången för laddning av start batteriet. Batterimonitirn är en från den gamla mastervolt laddaren.
Om det är ett trasigt batteri borde det inte bli varmt?
Klarar batterierna att det tryck på 2 amp konstant?
Vad heter den batterimonitorn/laddare?
Kurt Vilen
Laddaren är en Mastervolt Chargemaster 50/3 12v
När vi körde hem båten häromdagen larmade maskin för generator problem och då laddade generatorn 15.2 volt
Nu laddar den normalt..
2 ampere på fem batterier är ungefär 0,4 A per batteri. Inte farligt mycket. Sedan undrar jag vad laddaren har för ström inställt för att lämna denna fas och gå till ren underhållsladdning. Min Victron hade innan jag programmerade om den en fabriksinställning på 2% under, tror jag, 2 minuter.
