lördag 22 november 2025
Flipperpetri
Stäv upp i Raymarin 50d
Manualen sid 52:
Chart mode and orientation
Mode settings enable you to control how information is shown on
the chart, they let you change such things as how movement is represented,
the position of your boat’s on-screen representation and
the chart orientation.
Orientation
Orientation settings control the way the chart is drawn in relation to
your boat’s position and course.
To set the chart orientation:
1. Press the PRESENTATION soft key.
2. Press the CHART MODE AND ORIENTATION soft key.
3. Press the ORIENTATION soft key to toggle it to your preferred
choice.
Orientation options:
• North Up (N-Up)
This is the default mode with the chart static and orientated with
true north to the top of the screen. As your boat’s heading
changes, the boat symbol rotates accordingly.
• Heading Up (H-Up)
In this mode the on-screen boat symbol remains static, with the
current heading facing the top of the screen. When you change
the boat’s heading the chart rotates accordingly. However, to
prevent continual chart rotation as your boat yaws, the chart will
only update if the heading change is 10o or greater. You cannot
select Head-Up mode if the motion mode is set to True.
• Course Up (C-Up)
In this mode the chart is static and orientated with your boat’s
current course facing the top of the screen. As your boat changes
heading, the on-screen boat symbol moves accordingly.
When a new course is selected, the chart redraws to show the
new course to the top of the screen.
Stort tack har C-up nu och det är bättre. Vad är skillnaden på c-up och n-up: jag fattar inte engelsakan och inte gogle translate heller?
Senast ändrad av Flipperpetri | 24 juni 2012 | 20:24
C up kurs/stäv upp
N up norr upp, som jag vill hadet.
Kalle
Hittade en manual från säljsajt med en bra instruktion hur man bör ställa i plottern innan 1a turen.
Tex stänga av vissa satteliter, samt stäv upp mm. Synd att inte Erlanssonsbrygga tar efter och ser till att man får med dettta jätteviktiga dokument. Helt klart mycket nöjdare nu när allt lirar på direkten.
