lördag 20 april 2024
sme1972
Painting advice on deck
Hey,
Anyone answering this can do it in Swedish or English, but I write better in English
Anyhow, i just bought a 28 ft snipa with a great motor but cosmetically she needs a lot of work.
I will be painting all the old sections that used to have grey paint.
You can see in my attached pictures what it looks like everywhere right now
I am not very pedantic. I want it to look nice and last a few years, but I am not a perfectionist.
My wish is to be able to do this over maximum 3 warm days, but that is just my wish right now.
My idea for prep work is:
  • I will give it a good wash/scrub with soap and water, go over briefly with acetone on all the areas and then tape up the lines and then I was just going to paint. It will be grey again most likely.
I have many questions.
  • Is my prep work good enough that I mentioned?
  • It seems like everywhere except the section with skylight have slip protection already in the construction in fiberglass. If I want nonslip or at least decent grip on wet deck, do I need paint with slip protection paint also?
  • Do I need to use grundfärg?
  • Can I only use grundfärg since some grundfärg is already grey? I don't want a shiny finish.
  • Do I need to remove the tape after every application of paint  and then put down new tape each time.
  • Do I use 1 komponent, 2 komponent, osv...
  • Do I apply paint with roller or brush (or both), etc...
I am on a budget, so not looking for most expensive paint but not crap either. Any tips on which paint to use would be appreciated,
I am looking for someone who just says do this, this and this in a certain order, and I will listen to you :)
I am open for any advice.
The grey paint is most likely Interdeck by the brand International (Interlux) which is a slip resistant paint.
